LED blubs
I like using white led bulbs makes a car stand out plus you dont have that dingey yellow look from the sidelights im waiting for my 1 watt white sidelights the now they are pure white just like my xenons not cheap but worth it for looks
they are to replace the rear bulbs though. might just give them a whirl...
if you replace your indicator bulbs your car might flash alot quicker than normal as some of the bulbs use less voltage normally they flash quicker if one of your bulbs are out
you will need some load ressistors for the indicators to stop them flashing quickly
where can you get the bright side lights from? Are they a straight swap for the regular ones. Don't like the dingy yellow side lights tbh.
Loads of places do them ste.
ultra LED's is quite a good place to get them as they have all sorts!
the flasher unit is integral to the ecu in mk2 ph1 and 2 clios, believe me i have tried. i have all the leds for front and rear and a flasher unit going to waste in my garage.
the side repeaters however are not affected.
you can rewire the rear indicators to fit load resistors but they get so hot they sometime go wild. the front ones i dont know which wire links it as the bulb holder is the part that supplies the power through it touching the metal.
jamie
