is there a tool for cyfering (sp) petrol?
A syphon (sp) is what you want, the last one i used didnt need sucking to get it going as it had a pump in line.
My advice is do as Fred says and just wire up the normal pump.
It can be risky trying to do a bodge job any other way, apart from manual pumping.
Halfrauds do a kit. Just a rubber pipe with a valve in the middle. Put it in, give it a little shake to start it off and you're done!
what connetor? its just the top of the sender pump behind the drivers seat
where the pins are, under the flap behind the seat. yours looked like it points up where as my connections are facing to the side, making it hard to get anysort of spade clips, adaptions on it
Hmmm, not sure if I fancy arcing electrical connections near any petrol fumes ?!
Just go out and buy a proper syphon. You should be able to get one, with a built in hand pump, for a couple of £'s !
Oh, and petrol is very different to water so, you should use a specific petrol/diesel pump when transferring petrol !
Just suck it out with a clear hose............your good at sucking c**k and taking it out of your mouth before the money shot so should be a doddle for a man of your talents
i have rigged somthing up. will post a pic now!
if the positive and the earth were the wrong way round what would happen?
