Blocking websites on your personal computer
is there any free and easy way I can block certain websites being accessed on my laptop and home pc??
I am pretty rubbish with security so help would be great :approve:
aslong as the people that are trying to view the banned sites arent tech savvy then ye.. edit the hosts file and point the DNS entries to your local loopback address.
Go into c:\windows\system32\drivers\etc and open the hosts file with notepad
Add a new entry like so
127.0.0.1 google.co.uk
Do a search on the pc for host*.* make sure you search system folders, subfolders and hidden files in the search.
Right click on HOSTs (should be C:\Windows\System32\drives\etc) and say Open With.., open with Notepad.
Edit file
When it shows this:
127.0.0.1 localhost
Edit underneath it and say
127.0.0.1 cliosport.net
Then save the file as usual, then if you go to cliosport.net you wont get to it now.
Edit file
When it shows this:
127.0.0.1 localhost
I have done that, but it doesnt stop me from accessing Cliosport ???
Sorry for sounding dumb :o
see screen shot below of what I have done, I didnt press save as, just save. But it still lets this computer access facebook:
help......:)
The file should just be called hosts not hosts1 also you've made it a bak file.
Go to Tools -> Folder options then view tab and clear the tick box for hide extensions for know file types. Rename your hosts1.bak to hosts
In that case make sure 'Show hidden files and folders is on! The original host file is there you just can't see it. delete hosts1 completely.
yes got all hidden files showing, i have done a search for the file name hosts, and I seem to have 2 different directories with similar files in them:
C:\WINDOWS\system32\drivers\etc
^^^ that one where hosts1 was
C:\$WINDOWS.~BT\Windows\System32\drivers\etc
^^^^ that one where the actual hosts file is.............
I am confused :(
just try this for me:
Start menu - run - type: C:\WINDOWS\system32\drivers\etc\hosts and then click ok - use notepad - tell me if hosts opens up
yes it does....seemingly having different text in it to the other ones.....
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
#block wga
127.0.0.1 mpa.one.microsoft.com
try your entries in that then just click save :)
Your PC seems abit mental!!
That file is there you just can't see it also you got 2 copies of windows on your PC?
