as above give the TDC Sensor a clean there a b**ch this time of year and dont like the cold, does it bump start ?
with the symtoms you have described my money would not be on the tdc. What happens when you try and engage the starter?
So basically the starter isnt turning at all - so it would either be down to perhaps corroded connecter the starter solinoid or the started itself. You would need to confirm with some more experiencied members though as its difficult to tell without having a look
First thing i'd see if your getting 12v at the starter when you turn the key.
Its your starter matey
Mines doing exactly the same and has been for the past few months. Quick tap with a iron bar usually free's the sticking bushes all be it tempory![]()
You can fix that yourself assuming you can get to the motor to take it off, it just needs taking apart, servicing and putting back together.
