MOT
J03
Car  MX5 1.8
with my MOT soon, was wondering what are the common faults on the clio before my mot renewal arrives.. i know that the horn doesnt work when i want to any ideas how to fix it? and plus ive had new angel eyes so am going to swap them back for the MOT.. any common things to look for?
cheers guys :)
Does your area have alot of speed bumps / shitty road surfaces?
Mine does so im prone to cracked suspension springs or leaking break cylinders due to the special ed council making the speedbumps bus/humvee width.
Does your area have alot of speed bumps / s**tty road surfaces?
yeah my area does have alot of these shitty roads... any ideas to as how you check your brake fluids? and the cars lowered aswel... the suspension should be fine, only had them a couple of months
my horn broke to, just take the passenger wheel of and remove the arch liner, make sure the two connectors on the horn are attached and rust free. one of mine had just popped of
CV clips like to break off and leave the boot loose. Check those as your top priority :) Also there is a middle boot which sometimes rubs on some plastic dust guard on the drivers side, so make sure that hasnt worn through.
Why you swapping the angel eyes? Are they a failure? I wouldnt have thought they would be?
cheers man :)
wel just incase i get bent over for it.. i dont want to fail on something like beam positioning but everythings set up alright.. just for the safe side.. and i have LEDs which are not meant for the road so will have to take them out.
