Throttle body cleaned! (with pics)
Car  Ultra Red Megane 225
Just thought I would put some before and after pics up of the throttle body on my 172 cup
Before:
Oily, dusty residue had collected in the 'mouth' of it, and also half of the chamber was caked in same.
After:
Thats better! :cool:
seemed to improve tickover very slightly
(please excuse crappy phone pictures)
I don't think the TB is a major restriction tbh.
Worth cleaning. Although ,my idle went crazy for a bit when I refitted it.
there was a guy selling re worked 172 TB's on ebay with quite a bit of modifiying done but apparently they arn't a restriction and the 90 degree bend on the hose going from TB to airbox is more of a restriction.
did mine with WD40 few months ago ...its okjust dont go too mad with it cus theres electrics in the black cover
hmm just took mine off to clean and there was a lot of black. i also found a little rust spots. how car i get these off? car feels alot nicer on start up :D
sorry to bump in guys! speaking to a mate whos putting a larger tb on his mondeo... is there a bigger one available... i know alot of ppl would say its not worth doing would just like to know if theres one available like off the v6 or something?
Thanks
is the tb easy to remove? think mine could do with being cleaned as on 65k now so probably full of crud
Thanks
No point as the TB is not a restriction on the sport.
As above...filing down etc on this TB waste of time but if it makes you feel better then go ahead lol
Thanks
yeah yozzasport are testing their new one out i believe, its a stock one thats taken to pieces and then machined out and a larger butterfly is added (72mm IIRC but i maybe wrong)
same as this http://www.lohen.co.uk/shop/proddetail.asp?prod=LohenThrottleBody
It would be nice to see proof of gains as weel as details of the conversion as I have always been told the TB on the clio is not the main point of restriction and I am interested to see how much of a difference it actually makes.
yeah lots of people jumping on wagons and repeating what someone said about it not having an effect, but no hard proof
Needs to go hand in hand with a re-map. I've seen loss of power by just bolting on a bigger body (on other marques), but if you map for the extra air you're onto a winner. You do have to be careful to strike a balance between size of butterfly, and throttle control. Much bigger than 70mm and the throttle becomes like an on/off switch as just slightly opening the throttle lets in a lot of air very quickly.
Same I'd take his word over others aswell
The TB isnt exactly small compared to the ports.
as with pretty much anything, you'll get the best out of these things if you use mods that compliment each other. As you rightly say the ports are small, so enlarging and matching these whilst re-working the plenum for the large body works well. I'm personally not in a position to post graphs, which would be handy right now.
how much are the teams allowed to change on the racers? i woulda thought they would have done it if they could, as every bhp counts
