NTFS OR FAT32
brisa4984
Ok chaps.. Im not technical minded unfortunately
Im rebooting my computer and came accross this screen
Im firstly going to delete all partitions and create one.
But which one do I go for? Just want a standard operating system? Normal if thats anything to go by.
Any ideas?
sn00p
  A blue one.
quick only initialises the file system tables.
the others check every block on the disk. slow.
I only ever do quick formats on PC's because I can't be arsed to wait.
  133, 182, Kangoo 182
Full NTFS.
FAT32 is an older file system with (IIRC) 4GB file transfer limits.
  Better than yours. C*nt.
Full NTFS.
Only can have up to 4gb files, theres no real reason to use fat32 for the last 8 years or so tbh.
Marginal performance benefit of FAT32 over NTFS, as NTFS has a lot of overhead to run it's security features. However, in saying that you'll never notice the difference and as has been said the NTFS file system is much more advanced. On anything except the most performance-critical systems NTFS is the way forward. God only knows why manufacturers put anything else on their systems.
  ValverInBits
as said, 4gb file limit on fat32
NTFS is regarded as being more stable.
and go for the quick, there isnt a disadvantage
Full NTFS.
Cross OS compatibility.
A lot of operating systems, only have experimental or no NTFS write support.. only read.
NTFS is a proprietary filesystem, which is why it's always very experimental writing to it from anything but Windows.
If you run exclusively Windows, then use NTFS as FAT32 doesn't support acl's etc.
