Whats the extra click at the end of full throttle
Steve
Car  LMC10, Puma E
As above, when you press accelerator down it reaches a point then it can be pushed pass this???
If you have the cruise control/speed limiter facility in your car, this kickdown point is used to override the speed limiter and continue to accellerate normally. If you don't have a speed limiter then it does not do anything - I guess it was just cheaper for Renault to use the same pedal design, regardless of the feature level of the car.
it's random my 172 with no cruise control had this, the 182 with cruise control has no click.
Yeah they all have the click.
But it's for the nitrous injection, whoever said it was for the speed limiter is a liar!!
