will it fit
Why would you want to?
cambelt snapped an i can get a 172 cup engine from a freind,
but i wonderd if any 1 else has done it, an if their was anything differant as it is litrly sump,block,&head and was going to swap everything else over,
cam
I think it should be a straight swap.
Apart from the accelarator pedal has no throttle cable and it has a drive by wire throttle body on the cup which is operated by sensors on the accelarator pedal etc.
Which may be a fun job changing it all to suit.
I can't think of anything else but i'm sure someone will be on soon to add anything else ;)
thanks for the info,
would it be poss to use my origanol inlet and throttle body to oliminate this prob?
