xenon HID Kit??
Car  05 Clio 1.4
Does anyone know how to fit these conversion kit?? or know a place where i could get it fitted?? around stanmore/london area??
Most are just plug and play... basic instructions should be in the box
any local garage/car electric specialist should be able to fit it
Not so matey...had to take the bumper off my 197 to fit mine...look mint and work so much better than the standard kit..
He doesn't have a ph3 though, you can do it just by taking the headlamps off/reaching behind them with ph2 :rasp:
If you had to take ur bumper off.. did u just go to a local garage or to a renault dealer?
mine took less than 2 minutes to wire in it was a case of conecting two connection blocks together and i was done
We did take my front bumper and jeadlights off to be able to locate all 4 ballasts in a safe, dry place under the headligh assembly, it doesn't take too much time if you know the procedure, about an hour if you get focused on it.
