Automatic headlights not coming on!!
Car  Renault ClioSport 172
my automatic headlights are not coming on when startin the car ( obviously dependin on how dark it is ) !!
does anyone know why this mite be ?? :S
You can switch the function for auto lights off if you're fiddling round with the light stalk while engine is off, but ignition is on
Can't remember how though I'm afraid....check the manual it def says in there somewhere.
Turn the key to the second position and turn your dipped lights on and off twice it should beep. Think that means its activated/deactivated.
1. turn ignition on but keep engine off.
2. Turn headlights on and off until you hear a beep
3. Enjoi
//Aluco
engine off ignition on
switch the side lights on off on off on off untill you hear a beap...
re start it and hay presto
it anoys me a bit as when i jump in other cars when its dark i forget to turn the lights on
