anyone no about torque wrenches
Car  PH1 iceburg
If i wanted to get a torque wrench for the wheel bolts would i need 1/4" or 1/2"?
What should they be set too for tightness? :D
Ta, Dan
I think the official spec is 105nm, over torquing excessively is not a good idea as you're asking for a fractured wheel nut. I always re-do mine if it's been in at a garage as they seem to whack them up silly tight.
100 all round on every car for me. some people do them up far to tight it is rediculous.:S
1/2 Inch drive and 90Nm according to Autodata .
It doesn't really matter whether you use a 1/2", 3/8" or 1/2" wrench. As long as the required torque is in it's range, it will be ok.
If you are buying one, a 1/2" and a 3/8" is best as they have different ranges, but don't buy a cheap one or you may as well guess it.
Halfrauds torque wrenches are very good and are accurate.
erm yes it does
a 1/4 even if it did go to that high, which none do, it would break before you got to 100 or so nm
3/8 same story
how tight depends on your cars version 100NM is good though most people don't realise how inaccurate there gauge is anyway
