Part number :-)
Just changed a water pump and needing the part number that goes in-between the water pump ( 7700864596 and the bottom rad hose.
Its like a connector that joins onto the water pump with two 10mm bolts.
what car? i assume a 1.2 of some sort? you on about the plastic 90degree bit? that joins the lower rad hose
Think I might of got my engine type code wrong as it was a guess :)
Reg is P604 PUG
Engine code is 557K I think. Not B57A. that's where I've been going wrong :)
I think the part number is 77 01 041 346 can you double check for me
