galletto 1260 chiptuning tool
Car  clio rs 2000
hi friends
i have just bought galetto 1260 chip tuning tool
in the manual they said that it can support the most renault models including clio 172 with the ecu sirius s34
i want to learn about did anybody use this tool
does it really read and write the ecu program
the second question is my car is tuned by superchips, can i read the program and copy it to another clio 172
the immo is not important for us, we can recode it if the car doesnt work
i only want to know if i can copy it, the cars are both same
before i use it i want to ask it
im sure the maps are crypted and coded to the vin. technically you could but it depends on the sw / hw redoing this / csums
The cheap reader read nps, but expensive ones do all the legwork for you.
ok
if i try to copy the program, can it be a problem for the other car.
if there is a problem can i write the original one back
yes. 'tuning' refers to altering the various fuelling / timing maps in the ecu. on the basis you save whatever was there originally, whatever you change can be put back to standard by reapplying the backup which you saved originally
