Jokes aside, it should just twist off mate. If it's stuck my guess would be that the screw thread is cross-threaded or it's corroded under the ariel and a well placed spray of WD40 might help loosen it - just don't get that crap on your paint.
NOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!! now i find out dam it, is there anything i can do to make it fit lol and also do you know if the c2 VTS aerial will fit?
^ would depend on the size of the thread, a mk2 ph1 car & a mk2 ph2 have different sized threads, one if 5mm the other is 6mm, so if it fits one it won't fit the other..
think you will have to replace the whole arial man. the ph2 arial is a screw in type thing. our ones have a base that the arial snaps into sort of. not sure if the c2 one will fit, but if it does, pls drop me a pm
