CG New look trim gel.
Very thick, lasts ages (buff off for a matt finish)
In order of durability, look and longevity.
Blackfire long lasting Tyre-Gel.
Meguiars Gold Class Endure High Gloss Tyre Gel.
If you are applying it correctly you shouldn't lose grip with anything (unless you are driving on 2 wheels).
Yes, must be applied to sidewalls, NOT to the treads!
U should try AG tyre dressing BUT you have to spray carplan back to black on the top !! Its really durable and looks great. Been using both together for the past month now
the AG can also be sprayed in engine bay, anything plastic or rubber it does a great job on
i open bonnet, spray libarally then close bonnet, job done
my favourite product tbh![]()
Thats because it's the same product as AG Vinyl and Rubber care which can be used on the engine bay in this way , the only difference being the AG Vinyl and rubber care has a nicer smell .
so not the same :S
if your fussy a little aftershave splashed on the tyre wall will make it smell abit nicer?
If you actually know anything about the products maybe you won't make silly comments . Are you actually old enough to use aftershave, or do you borrow your dads ?? :approve:
I am pretty certain the post you quoted was meant as a bit of fun? After all, I do not think people really buy tyre shine products for the smell??
And as you appear to be picking people up on errors, it's "if you actually knew anything . . . " not "know"
jamie
What i'm actually saying , if you red my post correctly is that they are both the same products , but one , the AG Vinyl and Rubbercare has had a perfume added as obviously customers would want to use this product inside their cars and would rather have something that smells nice rather than something that smells of chemicals .
Now do you knew what i'm on about :rasp:
Oh and i was correct . It is know as i was talking in the present tense :approve:
Andy .
nano gel gives a really wet/new look but lasts approx 1-2 weeks. depends where you go.
yeh man i use this too, good stuff.AutoGlym Instant Tyre Dressing - Best![]()
Just about to use Blackfire for the first time... will report back
I think I've used EVERY other one, and not found any to be great tbh
