R27 LED
There are 9 LEDS in the roof liner and 2 on the door plus 2 behind the sunvisors.
Search
2pcs 501 W5W High Power LED (Blue) Dash wedge Bulbs
It reminds me of maxpower back in the year 2000 when everyone had those crazy neons inside their cars.
pmsl
did the make them much brighter in the lights at the back
If you are asking if the Brake/side lights are brighter, I would say a little, certainly not dimmer, being LED they do come on faster than standard filiment bulbs.
I have put Red LED behind the red reflector as you are supoosed to do something to do with the way light travels.
The Ultra white reversing lights are very bright.
The fogs are as bright as the brake lights when braking.
Out of interest, have you had to put in resistor packs for the rear lights?
When I upgraded my standard bulbs to LED ones, the car didn't understand the lack of resistance and so would not allow them to work (presumed no bulb was present).
Jamie
Jamie
These LEDS are fine, all lights working, maybe these are better quality with resistor packs built in.
Only problem was the hyper ticker on the amber indicator LEDS but I can buy a flasher relay for that, although I like the silvertec bulbs for that application.
Yeah that is the issue with LEDs on cars that come with standard filament bulbs. The side lights/repeater lights should be no problem, but all other indicators will presume that there is no bulb present, meaning they will flash quickly, just like when a bulb has blown.
The flasher resistors are awful (such has been my experience anyway) as they heat up to around plastic melting temperatures!!!!
Jamie
Jamie
Hi Jamie,
yep, I won't go down the flasher resistor route, all other lights are ok though.
looks awsome wher do i get them ?
and i want one for my reg plate light quick, mines dead and LED is the future lol
jamie
