Your having a bit of a nitemare with the car of late!
Aye :dapprove:
Lambda out, hole plugged!...........
Engine mgmt light on along with the "check emissions" msg and spanner![]()
How and where do I find the pre cat sensor??
You left it plugged in though, yeah?
Removing it from the connector will deffo bring on the msg.....
Cheers Si, will have a mooch!!just as the down pipes go into the first cat its screwed in on the top - a bit awkard to see from either above or below
This place have some but wont be the same make as the renault 1's
http://www.gendan.co.uk/oxygen_lambda_sensors_Renault_Clio_2.0i.html
