REMOVING DIAMONDS
The front one just pulls off, iirc the rear boot lock needs taking apart to remove the rear diamond.
wat he said, the front one just pulls straight off.
the boot one, the panel of the boot needs to come off and then undo the 3 scews that hold the boot lock on, when the screws are undone u will need to pull the boot lock surround off as its holded on by clips.
when its off u will see 4 plastic welds ( like bubbles) that hold the badge in place. u can either melt them with a soldring iron and then push it out, thats what i did or u can mask it and then spray it.
ill try and get some photos up off what i mean .
if your going to do the badges i suggest you do the "clio" badge too :)
Done my rear one yesterday, now have front and back done. Peice of piss to do.
How do you take the clio badge off mate? Its being held on by something...
It's held on by 2 push clips mate, you can either cover a screw driver and prize it off, will probably snapp though! Easiest way is to undo the star bit on the interior boot plastic and just push the clips on the back of the CLIO badge and it will just pop out, and it simply pushs back in when your done!
use a plastic card ie debit card and just wedge it from both sides, careful tho they are very easy to break, if they do just super glue it back
