Smaller radiator and fan
JW
Car  ITB 172 Cup & 197 FF
Is anyone running a smaller rad and fan setup on a 172?
Im in need of either and new rad and fan setup or maybe just a new fan but mount it from the front.
Need about 2" to get a decent filter for my bodies as the trumpets are touching the cowling at the moment.
What have you done or what rad / fans would fit?
we run a shorter alloy rad, with two small fans on back, one is controlled be ecu and other fan via a switch :D
This is using a short rad kit ive put together for the Mk1 Clios.
All cnc'd fan brackets and mounts.
The Mk2 version will be available in about 3 weeks if your still stuck then.
Retail is £250+vat (inc fan and fittings).
what you blanking old injectors with?
Looks good Stan. Whats the dimensions?
Cant remember of the top of my head.
Cools better than std, and its light as hell.
I'll put some pics up of the fan mounts. proper job, not bolts through the fins or owt daft!
