The noise is alot louder when the car is cold (first start), as said a rough squeaking noise.. Which goes away when you press the clutch down, then all you can hear is the dead clutch release bearing!
When you rev the car it almost sounds like an electrical interference noise/the squeaking noise spooling :S
Could be the bearing squeeking from cold too. Mine did this. Get it chaged asap as it will explode and do some damage. Look at Johnc172's cup thead and you will see what I mean
