fitting an induction kit
Car  BMW E36 328
Myt sound like a bit of a stupid question but how do i remove my standard airbox to fit an induction kit??
pics of the box? can't remember what you're is.
You should have metal clips round the induction tube which you use a screw driver to slacken off. Remove that to give more room. Then remove all the bolts that hold the box in place to the engine and lift out. You might have to disconnect any cold air feed piping before you remove it though.
Really easy job. Could be done in 5 min.
yeah mate, still not fitted it mind :) need to get a new filter and CAF tube for it. I've tested it and it sounds good.
So i just loosen the hose clip on the throttlebody and there are just a few screws holding the airbox on???
