One of the bulbs has probably blown, I know when I did my dash conversion that was the case with mine. Not sure what type they are but easy to replace once the dash is off
I recently got my Clio on Monday and have also noticed the lights are very dim, none of the bulbs look out its just very dull. I have it on the brightest setting on the adjuster too.
When you post a picture I'll compare it to mine. There is a guide in the guides section to remove the dash - but you have to become a full member to view it (£10).
take the top of the dash off:
- pull off the two coloured trim strips and the top of the steering column shroud
- remove the 6 screws now exposed
- remove 3 screws from screen demister channel
- remove plastic screw/clip from either end of dash
- pull dash free from clips (pull towards you) and remove
check the two bulbs in the bulb holders in the back of the clock
