Dash clock not veyr bright
  Fabia VRS
Ive just brought a 1.2 clio, and i've noticed that the data, time thing isnt bright at all !:(:banghead:
can anyone help or advise me what to do?
would be super if u did :hail:
thnaks :)
  N/A Currently
I think its supposed to be quite dim until you turn your sidelights on?
Although, it might be the other way round.... cant think off the top of my head
  Iceburg 172FF
I have tried that, and its still really dim :/ could it be the lights at the back?
One of the bulbs has probably blown, I know when I did my dash conversion that was the case with mine. Not sure what type they are but easy to replace once the dash is off
Ben
I recently got my Clio on Monday and have also noticed the lights are very dim, none of the bulbs look out its just very dull. I have it on the brightest setting on the adjuster too.
  Fabia VRS
Will try get a pic for tomoz, and how easy it to get the dash off and if anyone has a link to show me how to do it would be great :D
thanks guys
Ben
Might just be how Clio's are, I would go take a picture but its pissing it down here lol.
  Clio 182FF
When you post a picture I'll compare it to mine. There is a guide in the guides section to remove the dash - but you have to become a full member to view it (£10).
from recent (similar) experience -
take the top of the dash off:
- pull off the two coloured trim strips and the top of the steering column shroud
- remove the 6 screws now exposed
- remove 3 screws from screen demister channel
- remove plastic screw/clip from either end of dash
- pull dash free from clips (pull towards you) and remove
check the two bulbs in the bulb holders in the back of the clock
