Buying Extended Bolts For My Spacers - Which Of The Below Do I Need?
Hex refers to the head of the bolt (hex = normal)
fixed/loose refers to the angled bit (the seat) doesn't matter too much, fixed is better IMO
measure the length of your existing wheel bolts and then add on the extra you need
Measure the bolt and then add an extra 25mm to cover the spacer then yeah?
Haven't got a clue about stuff like this!
use hubcentrics instead mate. with non hubcentrics you will get wheel wooble at 60+ mph.
