Of course i do who hasnt
Is the RT a mk2 ph2 or ph1? If it's ph1 then you can get to the base by taking out the interior light section. The light unclips at one end and then the entire plastic fascia pulls off if you release the clips on each side. The aerial is held on with a small bolt.
Edit: can't remember for sure, but I don't think the ph1 aerial unscrews from the base anyway, not that it's of any help at this stage.
Never heard of this happening tbh, maybe who ever put it on before used locktite or something?
The reason it happened is because the gouges in the aerial weren't caused by someone trying to get it off, but a previous owner screwing it in with all his might, so it didn't get nicked and fcuking it up so that the housing became the weakest link. Simples.![]()
Not sure about the wiper. What wrong with yours?
Just didnt have one when i got it
Cheers Nick
Ah, don't forget to nick some headlight bulbs from the scrappy. :approve:
Its a Ph1 mate, I poped the light out last night and had a quick look do you know if you have to take the whole surround bit out??
left=loose right=tight:rasp:can you still get some pliers on it m8?, stupid question but are you turning it the right way?
