S3, Polo
I've stumbled across a leak.
About 1.5-2 weeks ago, I had the window down and noticed a burning oil smell whilst sat in traffic. I instantly assumed it was another car because a few days previous I had removed my undertray to just randomly check everything was ok (obsessive compulsive, you see?), and everything was as Renault intended, functioning sweetly and as dry as a bone.
Well, last week I removed all of my wheels so that they were ready for collection by the refurbishers, and I noticed the the driver's side driveshaft was wet with oil. I instantly assumed that it was a significant leak that had dripped down from the upper engine and been flung about by the spinning drive-shaft...
...Further investigation today revealed that it doesn't appear to be engine oil (the oil smells different) and the underside of the starter motor is wet with gold-coloured oil. Inspecting the o/s driveshaft and the point at which the driveshaft enters the gearbox is dry. It only shows signs of weeping at the inner (large) end of the inner CV boot, yet the boot doesn't appear to have been damaged in any way!?!? I also thought that the boot held in grease, not oil?
Everything on the n/s is totally dry. So is the gear selector (a common point for leaks).
Now, my engine and gearbox oil levels are still very healthy and whilst I was driving it, nothing abnormal seemed to rear it's head, but I'm desperate to diagnose the problem and either sort it or get it remedied asap.
Also, I'm probably being paranoid, but I don't want to drive the car like this, just in case oil contaminates my brakes or I exascerbate the problem.
Can anyone help me to identify the most probable cause - and approximate costs to fix this problem?
Cheers,
Ben
Cheers,
Ben
