Went out in a 550bhp S4 last night.....
Car  e60 M5 -172- dciheid
.............amazing.
built by these guys http://www.mrctuning.com/index.php?...ew=article&id=49:engine&catid=37:s4&Itemid=59
Rough spec (cant remember it all)
custom map
custom front mount (nicely wrapped into current front bumper)
t6 garrett
new fuel pumps
headwork
new suspension arms (non coileys)
my god this thing picks up like a treat at 1500rpm and flys.
Got 140+ no problems and that was just tickling it.
The brakes needed are rs6 6 pots, its one hell of a car.
To top it off, its ming blue
same as this minus the rs4 badge, tdi one going on
has same alloys.
makes clios look daft. badly want something 'that' rapid!!
loving it... perfer the newer shape though,
but who cares when you got that much speed aye?
i wish i had taken some snaps, its mega stealth due to the colour.
the coolest part of it, was the front number plate, it has the reg cut out of it, so that it can let air into the front mount.:clown:
superb!!
the way it picked up was sublime, was pulling silly in 6th and we had to slow down for roundabouts about a mile before they came up!!
:eek:
Looks nasty on those wheels, just don't suit the shape of the car. Driven a standard one, I'd rather have a 330 BMW regardless of how quick it goes in a straight line.
Great cars, i had a 390bhp avant, total wolf in sheeps clothing, full AMD conversion, frightened quite a few porsches, not too mention some others who got a fright, the torque was amazing, well over 400lbs/ft.
This was mine.
Full Milltek system sounded lovely.
No offence mate but thats the typical "I bought it because of the badge but don't dare admit it" type of choice. Ive drove both cars and the Audi is a much MUCH more capable car especially on the greasy uk roads. Its also put together better. As old as they are, my personal favorite is the UR Quattro with the 20v motor....................silly fast, especially when fiddled with.
his just had the red audi badge that is standard on them, love it big time.
perhaps a tad dated, but so f**k.
The Audi's faster and better built, but it's also got dull steering, and is very average to drive. The ur-Quattro is a different beast, as often said, the only fella that understood steering left Audi after they made that!
heres the build....
batman said:
Ive had this written up for a while, but thought I'd leave it until I was closer to getting it back, its been away for quite a while
I never planned on buying an S4 in the 1st place, i was looking for an Elise or Exige at the time.
I wanted a small, fun 2-seater. I wasnt even particularly taken in by the pictures of this car when a work mate pointed out that he was selling it.
The car in question is a '98 preface-lift saloon in ming blue pearl, sitting on 18" B7 RS4 reps.
A small cog in the back of my head started turning. Surely a big, heavy saloon car would never attract attention... From ricers, racers or even to an extent, the police. And that was it; i had to at least have a look, with the money in my pocket...
It seemed to be in good condition and so I took it.
Ive lost interest in the mechanical side of things, got sick of fixing beetles. This car also offered the opportunity of something i could stick in a garage to get fixed.
A few of you on here will have heard that 1 of my turbos seized not long after i bought the car. (3 months, with no symptoms other than a boost leak which I traced to the tbb then fixed)
The sticking point, which I only really realised after the failure i didnt want (and no offense) apprentices in a dealer or normal garage working on this car. Or even full mechanics who have grown complacent. So I made use of the AA’s “relay” service to get it down to MRC in banbury, who after some research were said to be "the" specialist for the S & RS4s.
So I talked to Lucas, who talked me through the possibilities within my budget. Straight swap, k04’s or RS6, and various different options with intake, exhaust etc. So it was between k04s and RS6 really, k03s werent a true option.
Meanwhile the guys in the garage stripped the engine out to check it over:
Engine out
Oil behind cambelt
Again, looking suspiciously oily, and corroded
Oily hoses :/ not entirely sure of what they are
The engine was then completely stripped, cleaned, inspected, then rebuilt.
Sourced a set of relatively new but refurbed RS6 turbos, had them modified to fit the S4, and hot side housings swapped for RS4 units for a better spool up time.
MRC intake pipes and tubular exhaust manifolds.
Engine rebuilt with uprated rods, rings, bearings, honed bores, full new cambelt and water pump service.
Difference speaks for itself really doesnt it!
The engine will also be treated to:
All new seals and gaskets (obviously!)
3" catless downpipes, link pipes and true dual Milltek which tapers to 2.75 at some point and ill be using middle and back boxes,
MRC front mount intercooler,
New 2001.5 intake manifold,
RS4 airbox, y-pipe & induction kit,
APR Bi-pipe,
Low compression head gaskets,
630cc injectors with spray patterns matched,
10 bar fuel pump,
RS4 engine and gearbox mounts,
MRC stage 2 clutch kit,
Lightweight flywheel,
New oil cooler,
Afterrun pump mod (low level temp switch),
New 710n divertor valves,
Slim-line air con fans,
And finally a proper map.
While the cars there, ive got them to fit:
New rear calipers, pads and disks (rear calipers were a bit siezed, I’d already done the fronts),
New steering rack (power steering failed after a few weeks, ordered pump and rack and the pump sorted it. Seemed a waste to have a new rack going to waste)
Heavy duty anti roll bars, front and back,
ARB support brackets,
ESP drive train stabiliser,
Drop links.
This was round about the time that my work went really quiet, and the build had to be put on hold.
This is how the car looked when I got it home after buying and then valeted.
Ok some pics of the car how it sat when I went down and visited recently:
FMIC mounted up
FMIC Near side pipework
FMIC Offside pipework + oil cooler
Oil cooler in place of IC
OS intake
New Fanimold
APR Bi-pipe
Side on
NS intake
DTS
Welds on exhaust
Flexi back
Awkward photo to take
Relatively clean for a 10yr old car I think
Milltek
FMIC and pipework will be painted black and bumper regrilled, not sure with what yet though.
Job got postponed (then cancelled) so last minute decision led to me flying down today and picking the car up so will get a couple of videos up tomorrow.
Really awkward at first but once I adjusted the seat from the "Doug" driving position I got used to the clutch a bit better!
Took it relatively easy on the way up, didnt bother looking for any private roads just straight home.
Not very exciting but I cant afford my insurance to go up any more!
Got a set of the mirror housings sitting here, came with the car. Cheers though
TDI badge also here
unfortunatley it was a VW one so has the red I but what the hell.
Will be making a body coloured mould to fit over the rear S4 badge and attach it to that for when I want less attention (or to scare people more
How many people are going to notice the difference out there? Probably just the ones that can tell its not an A4 eitherJob got postponed (then cancelled) so last minute decision led to me flying down today and picking the car up so will get a couple of videos up tomorrow.
TDI badge also here
All dry and maskers peeled off.
Lhs painted and back on.
Rhs
Bumper back on
TDI badge also here unfortunatley it was a VW one so has the red I but what the hell.
Will be making a body coloured mould to fit over the rear S4 badge and attach it to that for when I want less attention (or to scare people more )
batman again said:
Wee update not done any work on the car yet but picked up my MRC filter today, will fit that tomorrow morning.
Also having the passenger side turbo pipework changed on tuesday, going to try welding a 90deg bend onto the hard pipe between the turbo and IC at the turbo side and fit a silicon 90 between, hopefully stop it from popping off!
Crail times from my last visit:
Printouts from todays RR day.
North
Flywheel:
Crank:
South
[youtube]2gDsMeheXRQ[/youtube]
Thats very nice.
Shame you cant hear the engine very well on the dyno run.Is there a jet outside...???
ill see if hes got a better one on his phone, someone else took that one.
aparently he has tanked CSL M3s, lambos, ferraris and porsches. No bad.
subtle is king!
superb choice imo. All it needs is BBS alloys, lowered and some immense 10 pots up front
:D
aye and blended in with the bellend crew. Least this is stealth and will waste most things on the road
We heard you like reviving threads,so we put a thread in your thread so you can post while you post
Dawg...
