Clio 200 - 4 seats or 5?
MadUsa1
Car  Clio 200 Black and White
from discussion in another thread, there seems to be rumour that the 200 only has 4 seats, is that correct?
anyone have a 200 with 3 seatbelts in the back?!
I saw your comment in the other thread and thought "Pretty sure there's only two seat belts in the back".
Will check at lunch time but I'm still reasonably sure there's only two !
hmmm, strange. why would they do that? Have they not got the usual from the roof style one? otherwise having a middle seat is irrelvant?
so what are you supposed to do then? seems a bit stupid. Surely it should be advertised as a 4 seater and they could remove the middle of the seat to save a bit of weight ;)
Its an all in 1 bench. So impossible to remove just the middle.
4 seats. Its on the V5 as a 4 seater also.
I just checked in Croatian Clio RS specs - it is declared as 4 seater, while all other are for 5 people. I would just like to have two separate seats in the back instead of an all in one :)
The 172/182 is practically a 4 seater.. bit of the squeeze to get the 5th person in the back.
2 separate seats would probably weight more than the standard bench. So tb, I dont see the problem with them.
