1.2 16v mate.
What makes it an extreme, this is a real question.
Extreme speed would be my bet![]()
Does that mean the campus is for camping?
The badges.What makes it an extreme, this is a real question.
Cheers guys
Having a few problems however...
When it was delivered earlier today, it started first time and ran fine.
Now, basically, it just clicks and makes funny noises :/
The STOP light is on and a few others cant remember.
Also, the immobiliser light is meant to go pretty much as the ignition is turned on isnt it?
Mine stays on for a while and dissapears sometimes :/
Anyone have any ideas? Phoned seller and told him and he's willing to return money and fix it.
So, you put the key in, immobiliser off right? Turn key to start the car, turn key to full ignition and it just clicks? Does the starter motor go?
Clicking sounds like a flat battery
You need to understand what has caused it to go flat though. Try jump starting from another car or recharging battery. If it starts, great, but then go around the car whilst it's off and try and spot anything that may be draining power like the bootlight (classic problem on Mark1's). When you open the rear hatch tehre will be a black plastic button you can press down, press it down, is the bootlight off now? If so, that's good. Did you leave lights on?
If nothing is draining it it could be that you have a duff alternator or battery.
Either that or you have a classic immobiliser issue. You could try a trick I heard here, leave the key in the 'on' position for a minute and walk off, come back and try starting then...
I am not so good with the newer Clio's![]()
that happened to mine , mine was the battery though. put the key in turn it to the first click wait for the lights to go out then try it
I've tried that and waited for lights but the STOP light is on and it wont start.![]()
Really depressed and no impressed so far
Same as the one I had, the seats stain really easy btw but cracking car none the less.
Looks nice.
I thought mines was okay, xenons auto lights auto wipers.
Nice enough inside.
Steering wheel the size of a small country![]()
