Bulb recommendation please.
TC.
Im needing some new brighter (non blue) headlight bulbs. Can someone recommend me a decent set or post a link please.
cheers
OP: Are the bulbs for your Ph1? Non xenon yes? I think H4 is the correct fitment?
Those Osram bulbs where the ones i was talking about yes.
And those side 501 LEDs linked would look blue/white compareded to the Osrams, The Osrams look whiter than standard but still a little orangey. Im using Philips Bluevision as a side bulb, Its still a bulb not and LED and matches pretty well.
Best getting them from powerbulbs.com. The ebay links add up to more than £19.95, which is more that powerbulbs. You get the sidelights free as well.
On the dropdown menu you have location, make, model and year but its saying on the model option... clio (non sport) ?
I figured the website just assumes that all RS models came with Xenons. I'm now not convinced you need H4 though. Someone else needs to confirm.
Had a chat with the guy from powerbulbs and he had no answer for me either.
I got H1 and H4 night breakers and free Phillips side lights from PowerBulbs for about £34 delivered.
Work a treat!
Cliosport discount to check the list!
H1 Main Beam
H4 Dipped
Work a treat!
H1 Main Beam
H4 Dipped
Can you confirm theres no blue light off these
