Waitey ClioSport Club Member Car Alpina D3, AC Cobra Feb 7, 2010 #1 Car stalls when cold on starting, but will just idle when warm. Idle is around 400rpm but it still fairly smooth. Shagged ISCV?
Alastair. ClioSport Club Member Car 986'S 172ph1+182FF Feb 7, 2010 #2 remove throttle body, clean with brake cleaner or carb cleaner (same shiz) wak it back on and wala!
Daniel ClioSport Moderator Car Whichever has fuel Feb 7, 2010 #3 Is the K4m the 8v? If so I had identical problem. Idle control valve soaked in brake cleaner, blown out with an air line and good as new after!
Waitey ClioSport Club Member Car Alpina D3, AC Cobra Feb 8, 2010 #6 AliBailey88 said: remove throttle body, clean with brake cleaner or carb cleaner (same shiz) wak it back on and wala! Click to expand... Simple as that? Will give it a try later.
Martin_172 ClioSport Club Member Car 182 RaceVan / 197 Feb 8, 2010 #7 ^ yep had to do that with my mrs car was idling like a piece of s**t
Martin_172 ClioSport Club Member Car 182 RaceVan / 197 Feb 8, 2010 #9 cant remember off the top of my head but they do idle really low i always think ive stalled it when i get into it because im used to the diesel
AhmedRSi Car ? Feb 8, 2010 #10 Mine idles really low, 600ish after a few mins warming up. P.s - New car?!
Waitey ClioSport Club Member Car Alpina D3, AC Cobra Feb 8, 2010 #11 Well at the moment the idle isn't even registering on the tacho so it must be sub 400! It runs fine the rest of the time except you have to rev it and hold it at 2k when starting it from cold untill it'll idle.
Waitey ClioSport Club Member Car Alpina D3, AC Cobra Feb 8, 2010 #12 AhmedRSi said: Mine idles really low, 600ish after a few mins warming up. P.s - New car?! Click to expand... Nah its my GF's. I still have the saxo. Although i may swap the VTS for a 1.6 clio. VTS does 33mpg and the Clio does 45mpg!
