HTML Password Protection...
Rob
I've done lots of HTML/CSS etc so I don't need some long n00b explanation, just a recommendation on how to do it....
The situation is as follows....
We have
  • "www.cheekstuff.com/* "
  • "www.cheekystuff.com/woman"
  • "www.cheekystuff.com/man"
On cheekystuff.com, we have three groups of people who are trying to access content.....
Person 1) Should only be looking cheekystuff.com/ (not cheekystuff.com/anything) so without a password they can't see that bit
Person 2) wants to access "www.cheekystuff.com/woman" so needs password "a"
Person 3) wants to access "www.cheekystuff.com/man" so needs password "b"
Whats the best way to do this??? Java?
*Cheekystuff.com was created purely for entertainment purposes.
Just password protect the directories inside your cpanel.
Its the way i've always done it, php and cookies, not sure how secure it is, but thats never been an issue for me.
Care to elaborate, or link to where you code is nabbed from?
Not the best of hosts, not my host either (lol), I'm also accessing it via filezilla.
This doesnt need to be MASSIVELY secure, its just to stop a certain group of people at work viewing a certain directory.
I've found a php where you can select user and pword, then chose where it directs too?
using .htaccess file i would have said.
You can code users and passwords manually in .htpassword file or if you will have a lot of users then use Auth_MySQL options or similar to point to a database where they are stored.
Well what i've done and ^^ Bonxy inceidently (sp), is always have a mysql db, and set up the users in there, then use some simple php to check the in putted username and passwords match those in the db.
Then i just assign them a cookie with a GUID in, then on every page have some simple php code to check that the cookie exists, or to be more secure(not sure if it is) check the contents of the cookie matches the guid in the db.
so e.g. user signs in, gets cookie ( with guid in), that guid is added to the db for that user, then on every page check the cookie guid matches the db guid for a user, if so load page, if not don't.
not sure if that make sense?
<form>
<p>ENTER USER NAME :
<input type="text" name="text2">
</p>
<p> ENTER PASSWORD :
<input type="password" name="text1">
<input type="button" value="Check In" name="Submit" onclick=javascript:validate(text2.value,"USERNAME",text1.value,"PASSWORD") >
</p>
</form>
<script language = "javascript">
function validate(text1,text2,text3,text4)
if (text1==text2 && text3==text4)
load('URL/men');
else
load('URL/failure');
function load(url)
location.href=url;
</script>
This will work, but using this will not stop them from accessing the directory if they guess the link.
So you would put the following code in, say URL/men/index.htm then if correct it goes to URL/men/cliosport.
But if they guessed the URL like URL/men/cliosport they would be able to see it as it wont have a logged page.
I hope that comes accross ok. Ha..
Sam!
Does make sense yeah, cheers, may do it that way, its not something that needs to be done properly atm, just a quick fix, I CBA with setting up mysql atm and everything. (lol)
Its only going to have two users anyway.
Cheers for all the feedback chaps.
but if using sessions, check to see if there is a session open before letting them see the page
so
if the session is open
display this
else
{header.location=another page}
lol something along those lines
After the log in form that bonxy suggested have the php code...
$value = 'cliosport'
setcookie
("TestCookie", $value);
then on each secured page have the code...
if ($_COOKIE["TestCookie"] == 'cliosport')
load page
else
echo "bugger off";
edit: may not be 100% correct, but you get the gist:o
AuthUserFile /full/path/to/.htpasswd
AuthType Basic
AuthName "My Secret Page"
<Files "mypage.html">
Require valid-user
</Files>
Have this on your 'secured pages'
<?php
$value = $HTTP_COOKIE_VARS["TestCookie"];
if($userid != "cs")
echo "please go away";
else
echo "<a href=http://cliosport.net>cs.net</a>";
// put whatever you want in here
Then on your login have this..
<form>
</p>
<input type="button" value="Check In" name="Submit" onclick=javascript:validate(text2.value,"USERNAME" ,text1.value,"PASSWORD") >
</p>
</form>
setcookie("TestCookie", "cs");
</script>
tbh there may be an easier way of doing it and it isnt that secure.
With the method above^^^, you'll have to ensure the public cannot see the file, or anyone can go on and see the password(s) required.
If you have access to the file just CHMOD it, can't remember what code to but just look and it'll say "Read, Write etc", just untick read.
php is the best way mate, one of the simplest php things to do.
Basically you tell person A to go to www.blahblah.co.uk/a, obviously with the pass you've given them they can access it.
Person B - www.blahblah.co.uk/b, again the pass you've given them will allow access.
Do a search for it on google mate, I'll try and dig one out but I've got sooooooooooo many folders lol.
