Service light + ESP. Please read and help
Car  Fabia vrs tdi
At times the service and ESP light come on and is starting to happen more often but as soon as I turn engine off it sorts problem out
could this indicate a problem with the braked, I'm worried
just had front discs and pads changed 500 miles ago
thanks for your help
No just derive and ESP it's doing it alot more regular now but usualy turn engine off and it sorts it there is obviously a problem somewhere
meh mine's been on for ages, inc abs light sure its a sensor, going to get NW Performance to sort it when I take it there for its MOT June
Just concerned it's more than a sensor especially if it only comes on some of the time
maybe my brakes werent fitted correctly
mine was doing the same and then abs light came on as well, mines had new discs and pads all round since then, fitted by NW Performance so I'm sure mine is a sensor.
Might be worth getting yours checked though
Ok if it persists and stays on I will take it to the garage, would the problem show up on a diagnostic test?
Could be brake pedal switch.
Chris, when does your problem occur?
It happens when I start the car then turn it off and back on and problem sorted
I do have a habbit of sittin with my foot on the brake when engine is off
started gettin a burning clutch smell but prob just due to my driving syle lol
CPU is designed by Amstrad and built by Stevie Wonder manufacture inc - follow this easy guide below and it will fix it:
http://www.cliosport.net/forum/showthread.php?t=307978
happens on all Clios.
It isn't the brake pedal switch if the ABS light doesn't come on too.
Chris - yours sounds (obviously) like an ESP issue. The obvious thing is the switch, but doubt that'd bring on the Serv light too.
Get it on diag would be my advice (or find someone with an RS Tuner).
