Whats the correct torque for throttle body bolts?
nipped being between loose and fairly tight.
loose
nipped
fairly tight
tight
fairly fcuking tight
fcuking tight.
in that order.
Be careful with them bolts cos I tried doing mine up to 12Nm but I couldn't even get them that tight - I think I might have started to strip the threads.
Did tb and plenum bolts up tonight at 12nm and they were fine. Did feel quite tight tho and was a bit scary doing the first one on the plenum. Def wouldn't want to do them any tighter!
