Moose4624 Car PH2 172 Jun 28, 2010 #1 Was driving yesterday and my airbag and service light came on, and wont go off, any ideas? Im assuming some form of faulty sensor?
A Agent Car PH2 RS Jun 28, 2010 #2 Should be sensor or cable connections. Firstly try to clear errors on ecu by computer at services. If will occure again, will be done something
R richy22 Car Bumder With A Buffer Jun 28, 2010 #3 Have a wiggle of the connectors under the seat...That may stop it. COmmon problem on the Clio's
Phil_tilt Car Clio 182 Cup FF Jun 28, 2010 #4 i had this after having someone bump into me, think they are replacing a sensor
The Boosh! ClioSport Admin Car Elise, Duster Jun 28, 2010 #5 Check the guide in the guides section. Shows you how to turn the light of perminently using a set of resistors. But yeh, if you play with the wires under your seat it should turn its self off.
micp Car Lupo GTI Jun 28, 2010 #6 The Boosh! said: Check the guide in the guides section. Shows you how to turn the light of perminently using a set of resistors. But yeh, if you play with the wires under your seat it should turn its self off. Click to expand... I've tried the resistor thing after fitting 1*2 seats to my rep and it's not worked. Do I need to clear the codes first then fit the resistors?
