PCD converter
Clart
is there such a thing as a PCD 100 to PCD 108 converter? I have seen some wheels i NEED but they are 108 pcd. Offset is 35 too - is this possible?
Daniel
  Whichever has fuel
35 offset is fine.
Unsure of the pcd though. Hub adaptors? Although 35 offset and hub adaptors will leave the wheels quite stuck out i'd imagine.
  Black Clio GT
yes you can get them, min you can get pcd adaptors in is 15mm so that would leave the wheels et20 which would need some streched tyres and possibly a touch of negative camber to get under the arches......
  Dodgy one
No chance on a 172 unless you want no arches left, What wheels are they? You can get them drilled, but if they have no cap it'l look w**k!
  Black Clio GT
depends what size they are, if there 15s and not massivly wide bet they would fit quite nicley, with some camber bolts and shims...
  Mk2 1.2 Campus
Ive had ET20 in 16s and it was catching a little. If the wheels have flat backs a decent engineering shop will drill new holes
