Throttle body question
Car  Stagecoach Ticket
Had a quick search couldent find much info not even sure its possiable but thought i would ask if anyone knows.
is it possiable to fit a larger standard style throttle body in place of the standard throttle body on a ph1 172 lump?
Has anyone done similar?
James
jenvey body requires the plenum inlet enlarging and new threads drilling and cutting, also makes a masive difference to use the 100mm bellmouth
When I tested the air pressure in the mani, at full throttle the inlet want full, so in theory a larger t/b would allow more air in. But the problem is due to the larger opening, the car will be getting x amount more air, and tend to be very snappy as your getting more air in.
And as Danny said, they need a bit of work to fit.
So refere to Freds post lol
would you see much gain from it? do you think steve or £200 best spent else were?
Not sure TBH mate, Andy Cutler (GDI) did offer a package but that did include cams and it was supposed to be good.
As Danny says you'll have to port the inside of your inlets to ensure a good match but I'm sure the PH1 throttle body is the same square bolt pattern as the Jenvey, the fly by wire throttle body has a rectangular bolt pattern.
it worked well with cams indeed. none of the bolt patterns are the same sadly
