Fuse for the OEM head unit?
Darren S
Guys,
Any idea which fuse would be responsible for the head unit on a 182? Just want to check the obvious things first as to why mine's not working.
Cheers,
D.
Hi
If you open the passenger door there is a fuse panel adjacent to the dashboard. If you remove that small panel there is a fuse symboled layout. off the top of my head it is a musical note! have you no power at all..... what is your exact fault?
Si
Cheers Simon,
The head unit simply does nothing. It has no orange backlit lights to it and the On/Off button does nothing either. I've ejected the unit, disconnected the connections at the back and reconnected them. Exactly the same. :(
I don't know if the unit itself is fecked, or if it's something as simple as a fuse.
D.
The best advice I can give is initially check the fuse. I don't know if you have a volt meter/multi meter and if the fuse hasn't blown it may well be checking if the unit is receiving power from the altenator power and the battery (turn the key to the first position). Ive just broken down my oem hu and can't find any other obvious fuses.
let me know if youre still having problems and i will have hunt!
Si
Thanks Si. I'll wait for a break in the bloody rain here, before I go and check on the fuses!
I haven't got a multi-meter unfortunately and know jack all about electrics. :(
D.
You should have a few spare fuses on the panel Daz. Can't remember which fuse it would be, but it might say in the hand book
Checked the fuse guys - I found the corresponding 15amp one in the panel and swapped it with the spare. Still no joy. :( The original 15amp fuse still looked fine too - no clean break in the connector or anything.
I don't know whether to invest in a multi-meter first, or to just try and borrow a replacement head-unit and see if that works?
D.
Hi Steven
In my industry we use "Fluke" multi meters - bloody expensive but I think I paid a fiver for mine from B&Q. All I can say Kerry is I wish I'd known I could have gotten one for a squid! Anyway back to topic, have you mananged to remove the unit to check the connectors at the back? Just a random and I've not had this sympton on a Renault but does the stereo work with the key turned to the first click or is it completely dead?
Si
Hi Steven
Si
I'll eject the unit again in the next day or two and double-check those connectors. As it stands, the unit just doesn't do anything. No backlit numbers, no function on/off or anything....
D.
