wheel spacer torques ?
b*****d tight. Honestly though i'd just do them up tight. Ive torqued my wheels up before and within a month they aren't as tight as they should be.
Also, on the way back from our euro road trip, grays front wheel started wobbling (even though he torqued up). Pulled over on hard shoulder and most of the bolts had come loose.
I just do my wheel bolts sensibly tight (obviously without bouncing up and down on the wrench)
Yes mine bolt to hub then wheels bolt to them they are eibach hubcentric 30mm spacers with steel inserts? But it doesn't tell me a torque setting. I would like to torque them correctly so I don't need to check them all the time worrying. All it says is torque them then drive for however many mile then re torque them. I just don't know what to torque them too??? Lol
Phone Eibach. Probably you will be ok doing them to Renault recommendations.
With a wheel spacer that bolts onto the hub, its advised that you do it to the correct torque settings. Do it too tight and there potential of snapping them if driven hard.
you are more likely to cross thread the hub than have them snap. Not good either way though...
done them :D :D :D i did them at 120nm in the end ?
iv got 30mm on the front, i put 25mm on the rear and it looked soooooooo nice. drove it up the road and was rubbing like a dry pussy so had to take them off :(, once i have put the shims on the rear it will be ok though. i cant wait to put the lensos on now!!
