MOT de-cat annoyance
I need a 182 mani and cat, but cba the 10 hours labour getting one of these fitted!! Even though they are epic :) I think I have a de-cat mot sorted now, just gotta leave the car with him for a week to do that, fit my matched inlets and fuel line so its no longer held on with cable ties :/
Can´t you get the 182 manifold via Renault Motorsports, should be around the 300 mark...
part no is 7711155545
switching 172 cats is just disgusting work for people with childish hands. imo it is worth the hassle to upgrade to a 182 mani, cat/decat exchange is about half an hour then...
You can't just use a 182 cat though can you? You either have to buy the K-tec sports cat or decat.
The limit for mine is 0.20%...mine was 0.17% and that was at the 3rd attempt I think! Pulled the sensor out a bit.
Seems mine is poorly and running very rich :(
IT should only be about £40 to change it...Dont you remember how much we paid when we swapped Yozza's and Stealth?? £90 for all that I think?? :S
That's a seriously strict limit!!!! doesn't surprise me in the least that it's hard to achieve. Seriously rich sounds like quite an over-statement though. Remember it's not that long ago that cars didn't run cats and the MOT CO limit was 3.5%. If you have a big exhaust, you're probably just getting gas reversion causing oxygen to be sucked back in. Wet rag up the tail-pipe at the same time as the probe to reduce the exit apperture can sort this out and give a true reading
Il double check my MOT thingy me bod but I swear the limit said 0.20%. Good job I put my cat back on otherwise I would of been well over!
Exhaust is an HKS Superdragger off a standard evo8 so yeah its not small!
