brake lights and indicator help
Car  astra gsi/cliosport 172
the gf got a pull last nyt from the traffic as when she brakes the indicator light on the n/s comes on any ideas guys is it common ?
Take the light apart so you can get to the connectors (pins) and clean them up...plus check the earth wire :)
cheers guys just did the earth and then noticed that the connectors were a wee bit rusty and clend it up plugd it bak in and it wasnt working at all so pulld it out slightley and its working tho its a bit templmental?
Mines did this, when I pressed the brake all my indicators lit up, cleaned rear light connectors problem sorted.
It's a pain in the neck, chances are it will happen again so keep on top of those connectors.
I'm getting a similar problem ,guessing it's the same story.
indicate left, when the lights are on, and I get the rear fog warning light.
going to tear the cluster out and do the above, will update
Had this back in September, fog lights flickered when I indicated left?? Removed & cleaned connectors, sorted!
And the update is that after no time at all, and doing very little, it's all fixed
A squirt of WD40 on the connectors and that was all I did. There was no corrosion or dirt built up, did both light clusters and the number plate light whilst I was at it and now all seems dandy
