182
hi, i know this can be done but not sure if my laptop needs to have a hdmi port as it doesnt, is there an other way of doing this?
vga if your tv has one (which it most likely will have) or even a usb - av cable will work
You just need a VGA lead ( the same that comes with any regular monitor ) the main question with that solution though is does your TV have a VGA port? I'd say it's fairly unlikely it will
a samsung mate, my mams new laptop hooks up straight away through a hdmi but my laptop being a few years old doesnt have a hdmi port on itWhat TV are you hooking up to? Also do you want audio out through the TV as well? As that is where it gets more difficult in general depending on the TV and if you do or do not have a separate surround type system you can plug into.
I connect to my tv this way, I used to do it for iPlayer before I got the ps3.
I used the VGA cable for the picture, then ran a cable from the headphone output on my laptop to the aux sound in on the tv. Sounds a bit of a PITA but it was really only 2 wires.
Is this what you mean on the back of my laptop?
So do i need a cable from the blue port, to the same kind of port on my tv...on ebay ther are vga port cables with hdmi on the end, could i get one of those cables and conect the hdmi end to the tv?
I would go for VGA to HDMI.
Nice pic of ur car next to mine in June btw Mike![]()
i bought this http://www.kenable.co.uk/product_info.php?products_id=1979
with one of these http://www.kenable.co.uk/product_info.php?products_id=1371
works well and was delivered quickly
