took the car out today, if i hold the clutch in half way it makes a grinding noise like to plates rubbing! sounds almost like when u have no brake pads. It goes when the clutch is fully depressed or out of gear. You can here it when driving but not when accelarating. But seems to be louder when clutch is half way engaged.
thrust bearing would be cheap if u could buy this on its own but i think they come as a clutch kit but taking the box off and doing it if you can is time consuming but if you had somone to do it £££s unless you know somone to do it on the cheap
