Helpp Clutch :((((
  Renault Clio 53 1.2
my clutch once the engine has warmed up (about 10 to 15 minutes) starts making a squeaky rattle sound when i push it down, you can feel the squeak, when you push the pedal down any ideas what this may be?
  172 Sunflower
My 172 did it for several months before the release bearing finally collapsed ( it had done 100K and in a 172 thats good going ).
If you have a 172 then start saving ( £400+ fitted ) ! As i see you have a 1.2 i doubt its too big an issue....
B
bluebell
My 197cup just had a new clutch and she only had 29,000 on the clock.... claimed under warranty but it would of cost £1200 according to Renault Cardif....:eek:
  Renault Clio 53 1.2
did you have the same problem, cause if its a new clutch i am screwed thats a lot of $$, although guessing yours is a sports clutch, mines only a 1.2
B
bluebell
I only had the car a few months when it started slipping ...... cost wise i think it was labour more than anything cos the clutch os a nightmre job on the 197 pretty much engine gearbox out job...... not too sure bout the 1.2 i had a 1.2 and i never had a days problem with her had her lowered full body kit se was a dream......... hoping my 197 will be the same....
  Renault Clio 53 1.2
there are great little cars and its not a problem the car still works fine, its an annoying sounds, and wondered if its going to lead onto a bigger problem :/
