turini question..
  Westy. MX5
There are different ET values on Turinis and The Renault OE version is different to the Speedline one, not sure what but it's been mentioned here before.
Daz.
  Clio 200 RS EDC
All turinis will fit all 1*2 Variants.
The widest will be the aftermaket ones, then the cup ones, then the trophy.
If you're planning on doing some stupid lowering then the trophy ones would be the best bet.
Christopher
  Z4M
Simon's right, both will fit but Trophy Turinis are the ones to go for if you're planning on going low. Cup Turinis are a lower offset and would foul the arches at the back.
  182
im not planning on going low.. eibach prolines came today.. just want a set of turini's.. so the trophy turinis will fit fine with no problems??
Daz.
  Clio 200 RS EDC
Was going to start a new thread but found this one, i assume the hubs etc on the 172cup and 182ff are the same? If so why did they fit different offset wheels on the trophy?
FatRS
  Megane 250
Apologies for hijacking the thread but I have just fitted coilovers and will be fitting 172 cup turini's to my FF172, so will the wheels likely scrub any arches or even fill the arches more as since having coilovers fitted the wheels (in particular front) are badly inset and as such I've been looking for advice on spacers?
The 172 cup turinis have a lower ET as the track on the car is narrower than a 182, and a ff182 has a wider track again, so if your not going to lower other than eibach springs, all turinis will fit no problem...
Thanks :) does the trophy use cup hubs?
