You need to fit a resistor into the airbag connector, basically fooling the car into thinking the airbag is plugged in.
Thats pretty bad for clio owners, there are loads out there with the Airbag/Serv problem without a clue what to do, good for Renault garages i suppose.
How do you know that it will be a fail?
Where do you clip these resistors?
Into the airbag plug.. Bridging the connections.
3.3 ohm do NOT work. Recently changed my wheel. Airbag/Serv light were on/off before this. Now permanently on even with the resistor fitted. Annoyeeeddd!
