Fogs or no fogs?
Car  Megane 225 F1
Want to take mine out. Never use them unless I'm flashing c***s with the rear fog lights on, but I can use my full beams for that ;)
Anyone got any pics of black 1*2s without fogs? Also is it hard to use them for brake cooling? I heard there is some s**t behind them that needs moving around.
I will be taking this on track this year, so brake cooling will come in handy....and on hard road use :o
Someone is making a kit for the cooling ducts iirc. and its only the horn and carbon cannister to move
I did it. Removed the lamps. Left the surrounds.
What do I do with the cables? I mean, what happens if they get wet being exposed? Best to tape them up? Couldn't get any pics as it was dark when I finished :(
Tape them up and stick them to the inside of the bumper, then remove the fuse.
You'll need to remove your arches if you want to use them as cooling ducts aswell as the things already mentioned.
I'l sort the taping out tomorrow then.
N00b question. Fuse is in the side of the dash of the passenger side right? How do I know which fuse is what :o
got any pics? im tempted to take them out of my iceberg.
Any pics of black golds, my passenger side fog is cracked and currently taped so i might take them out..
Whats the deal with moving the carbon canister/fogs ? and can you just cut holes in the arch linings to run ducting/pipe ??
When you remove the little panel it has markings on the back to show what each one is.
