Decoder fault.
Tunst
Car  Focus ST225, Focus E
As title, car wont start cranks a couple of times then dies off. Plugged my scanner into it tells me there is a fault with the decoder ring... This will be a reno job? As the keys will need to be coded to the new ring etc?
Only just got the f*cker back yesterday, was perfectly fine till now :dapprove:
no not a renault job to fit the decoder ring , and they are not coded , its just a reader.
whats the immobiliser light doing ?
check for water ingress into the engine fuse board , esp where the relays are.
ah well thats easy enough, il order one tomorrow and get it fitted. Immob light is just flashing, iv checked for water etc and theres nothing. Il go with a new ring since thats what my diagnostics scanner says :rasp:
Iv managed to get hold of a second hand decoder ring and key, it will only start when the key is near the ring, also only one of my keys starts it the other wont, until the my other key has started it.
is there any way i can "code" my keys to this decoder ring? or am i going to have to buy a new one?
