ebay rear discs
Car  Clio Trophy
has anyone ever had experience buying the rear discs you see on ebay with bearings in them?
what are they like and are they a simple swap over if the bearing is in them?
thanks
Yes it is a simple change as long as you have a large 30mm. socket to undo the hub nut and a torgue wrench to tighten when you are done. I have no idea what discs they could be or how good but Renualt oe's are good and if you want cheap and adequate then GSF (Cliosport Discount as well) do the Ingersoll ones with bearings.
not sure which ones you are reffering to but i had a bad experience with cheap ebay discs & pads (for an alfa 147 though) - shite fitment and ended up not fitting the pads and having to buy again - buy from a respected brand or outlet and dont go for the cheapest is my advice
